a little info about anti lag & megasquirt please
(In Topic #107036)
Im guna be atempting to turbo a g40 lump but i want to run anti lag with it and i wanted to no firstley how does anti lag work? I no it changes the ignition timing but im not quit sure how it all works
Secondly can anti lag be used with mega squirt?
Any info work be greatley appriciated.
gaz
keep on dubbing
Implementable in megasquirt :dontknow: Possibly not, because you'd need additional inputs to know when to apply it (ie during gearchanges up, under power) and have a piece of code which switched to the retarded ignition and probably also altered the fuelling in some way or other too.
next question is which ecu will have the neccessary inputs and software available to run anti lag?
or would it be easy to leave the charger on nd turbo it would i need to lower the compression raion down even more?
the turbo ware doesn't bother me as i have now found a bloke round the corner from me who scraps cars but keeps them on a farm till the price of scrap is good i asked him if i could buy scrap golf gti's and passat turbos anything with 20valve turbo engines in off of him to strip and he said i could take what i wanted if i give him the shell back to scrap. so can get ahold of the turbo's pretty cheaply.
keep on dubbing
1982 1.8T-20v-GtEfi. K03S. Megasquirt. 16v Servo + MS. Relayed lights. Mk3 Wiper Motor… Getting too Reliable!
With thanks Eddie-Toyotec, Ben-Bens_cab, Brian-Broke and the Mk1 Owners Club! 211Bhp, should get 250 on next map!
keep on dubbing
