4 to 5 speed conversion
(In Topic #137721)
My question is do i have to change the drive shafts from 90mm to 100mm shafts? :dontknow:
cheers Darren.
1983 mk1 golf gti campaign
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
rubjonny said
what engine do you have now
i believe it to be a 1.5 from a gl. any more information needed?
just the flange issue to worry about then, your car has 90mm shafts so ideally get a 5 speed box with 90mm flanges to maek your life easier. or swap flanges, or swap shafts as above.
only 1.5-1.8 8v gearboxes will swap on with your existing clutch, mk3 2.0 8v and mk2 1.8 16v require a mk2 16v clutch kit. if you go for a new clutch either keep your old flywheel and fit 1.5 clutch, or find a 210mm flywheel from 1.8 mk1/2 and fit a gti 1.8 8v 210mm clutch kit
HTH
rubjonny said
measure the flanges just to be sure, theres no telling what box the mk2 might have as they like to blow up
Measured them today and there the same size as the 4 speed one's luckily
Another question mate is do I just bolt on the rear mount (square bush) on the 5 speed box as it was on the 4 speed? And then cut off the the ally mk2 mount which is surples or unbolt it and bolt on a mk1 gear mech? Hope that makes sence :dontknow:
Cheers Darren.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
the bottom square mount is the same on the 4 speed, but you will need a 5 speed MK1 upper box mount though
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
Cheers for all your reply rub, you've been a great help
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
can you take pictures of where you're at now?
Cheers Darren.
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
yeah bolts will be fine, just make sure they dont bottom out before getting tight is all
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
1988 mk1 caddy 1.8
1988 mk1 caddy 1.6
1991 mk2 golf gti
1996 mk3 golf gti
