2l bottom end?
(In Topic #80311)
2l bottom end?
1. What has to be done to the distributor to make it work properly?
2. What happens to the oil cooler, will it bolt on the 2l block?
3. Does it use all the original 1.8 water pump radiator etc?
4. Which breather on the 2l has to be blocked off?
5. Which 2l block is most practical for the conversion?
And if theres anything else anybody wants to chuck in for good measure i'd really appreciate it, sorry for all the Q's thanks in advance Rich
Mk1 1983 Helios Blue GTI Engineering
Check out these clubgti links for pretty much everything you need to know if it's a 16v.
http://www.clubgti.com…um/showthread.php?t=41171
1.What has to be done to the distributor to make it work properly?
You need to take the spline off the bottom of your 2ltr dizzy on put it on your mk1 dizzy. To use your mk1 dizzy you need an adaptor ring to make the difference in the size of hole on the block. Once this is fitted you will then be able to adjust the timeing in the same way as when doing it in your mk1.
You can use the oil cooler that is on the 2ltr block which is water cooled instead of the air cooled one on the mk1. If you wish to use an air cooled version you can buy an adapter plate but there is no need.
Water pump is exactly the same so all your hoses will meet up.
The breather doesnt have to be blocked up. people have different ideas about this TSR do blanking plates mainly to tiedy up the engine bay and give you some where to mount your warm up reg in a good position so it gets max temp from the block. Sometimes these breathers just vent off to a catch tank.
2e from passat / mk3 golf. Or an Audi 80 sport but this has a differnt engine code and is harder to find. The 2e is 12mm taller although someone is bound to say different.
Mk1 Lahsa green, BBS RM, Mk1 Silver Campaign, Mk5 GT TDi, Audi A4 Avant S Line
jonathanproctor said
hey mr mk1 turbo, r u selling a block? if so how much u want cheers, ps im losin my computer for a weeek for repairs, perhaps u could txt me? 07970 871017 cheers dude
Sorry mate its sold.
gti0000 said
This may help, the bubble block has a 3a engine code, these engines are in audi 80's produced between 89 and 91. you can use the existing dizzy, and just advance the timing a touch (no vac advance on 3a engine) car will run ok. You can pick up audi 80's for about a hundred quid off ebay without MOT, weigh the audi in for scrap after you'll get about 50 quid for that so the conversion has cost you about ?50…ish. You do need new head gasket about a tenner!
Get an audi 80 sport. Sell the 3 spoke steering wheel, VDO gauges, rear spoiler and clocks on ebay. Free conversion :wink:
