22.2mm master cylinder or 22mm master cylinder
(In Topic #87906)
Thanks.
have a look in the braking faq for more info.
Matt
matt18t said
Does anyone know which year for the passat 22.2 mm master cyl as I phoned europarts and they dont have it listed for either the g60 or the passat even better if you have a part number. Cheers
Matt
Passat 1987 - 1992
Got mine from gsf. Can't remember part number though.
im going to ecp or gsf to pick one up tomorrow and sourced a servo from a new vw scrappy in manc
would just like to see what it looks like fitted so i have a before and after picture for reference…
once again the haynes manual proves its worth or lack of it!
ie so you have one front and one rear pipe into the front section of the M/C and one frnt/one rear to the back section of the M/C.
your mk1 m/c I assume has 6 outlets, 2 each side and 2 underneath, 3 on each 'circuit'. The new one will have 4 outlets, two on each side.
Teh M/C will bolt straight on like the old one. You'll have to bend teh existing lines a bit, no problemo though. T piece's required if you want to keep the hydaulic light switch (mines got two, one in each circuit). Or pull the switch wiring back into the cabin, and fit a switch to the pedal box.
Have a gander in the FAQ:
http://www.vwgolfmk1.o…orums&file=viewforum&f=16
