20vt with megasquirt, fuel pump clicking off
(In Topic #143552)
anyway sounds like a loose conection that is arching so getting worse over time. check connections to relay are tight. may also be internal ie on a pcb, dry joint that has worked loose! had a similar prod with an imobiliser once easy fix but hard to find.
stu
