20vt wiring advise please
(In Topic #142377)
I'm clueless when it comes to wiring,the mrs uncle would get the job of fitting the wiring as he's a vw specialist but I would like to do as much as I can myself
Any help advise would be great
Cheers,Sean
Cheers mate
so jonny, if i wanted you to do this to use my mk1 fuse box… what do i need to send you?
when i make looms i need the donor engine loom (both halves for mk4) and the engine loom from your old car or any other mk1/cab/caddy with same fusebox as yours. 1.0-1.8 makes no odds just as long as the fusebox is the same
boom do i put a deposit down or anything like that?
EDIT: im pretty sure i booked in with you earlier - possibly a month or so ago… cannie remember lol
basically get the ecu, i need everything that plugs into it. mk4 have 2 halves of loom that go to ecu so i need both halves. if you're happy that passat is ok in your bay then i can do it for you
seams like i may be missing some part of the loom possibly?!?!
ill deffo book it in… whats the next process?
