20vt not running a heater, Pipe housing UPDATED
(In Topic #107268)
or does any one make an alloy version of this?
75 golf L 4 door Swallowtail
78 Custom 2 door Swallowtail 1.8T
02 Mk4 Anniversary GTI
07 Mk5 Edition 30 - stage1
cheers.
I found a couple of places for info if anyone else decides not to run a heat.
http://www.vwmod.com/project/swap3.php
and a site that shows pictures of water housings you have to flick about a lot but there is some pictures of water housings.
http://worldimpex.com/parts/genuine-part-coolant-flange_7403.html
anyway heres how it started. cut the raw alloy to size.
each piece was set on a lathe an faced and drilled out to size with a use of a boring bar.
Hose stop kept in place and chamfer for easy fitting of hose
Plate set up on the mill just having the ends reduced.
Parts made ends shape to fit. Then polished up ready for welding.
Trial fitting before polishing.
All finished and welded up and a final polish.
final item all in place just need to get a gasket cut for it.
Thanks for looking Mk1retro….
This is the first bit of machine work I have done since school. but I did have the help of a friend how used to be an engineer and knows all the tricks of the trade.
Material was off cuts from a local metal supplier ?15-?20 ish still have a lot left over.
man hours was the main thing, two of us on and off over 3 days maybe 9 hours total I would say. but done in between work time so no cost, but if I had to pay for somebody else to do it maybe ?100 plus
welding done by a metal company across the road from us, a cost of ?35.
not the cheapest but a very good learning curve and a total one off.
G60
from what i can see engine looks really neat
do you have a build thread?
mike
