20vt fuelling
(In Topic #135718)
20vt fuelling
Im going to be using the kjet fuel pump, do i still require the accumulator?
Thanks guys.
can get a barbed banjo fitting off ebay which converts the threaded fitting on the pump to a push fit fuel line fitting, can then use rubber/nylon pushfit hoses and a digifant fuel filter.
with the 1.3 tank you will need a later cabby/rocco or mk3 polo lift pump and fuel reservoir to prevent fuel starvation issues
Im changing the tank to a gti tank so the lift pump should be alright? Do I still need a reservoir?
this is the kind of thing i mean:
http://cgi.ebay.co.uk/12MM-BANJO-8MM-HOSE-M12x1-5-BOLT-FUEL-OIL-/390330527114
http://cgi.ebay.co.uk/12MM-BANJO-6MM-OIL-HOSE-M12X1-5-FUEL-HEAD-FITTING-/280651594831
choose the one to match fuel hose size
you dont use the included bolt though, rather you use the old domed nut off the pump. if you dont have that, then you'll need this one:
http://cgi.ebay.co.uk/BOSCH-COSWORTH-RS-TURBO-BANJO-OUTLET-M12-FITTING-SILVER-/160361266188
Then all I need is the kjet pump and swirl pot off a mk3 polo?
Is that foam holder for the fuel pump still available?
Btw regarding our conversation earlier, the gti lift pump only has 2 pins. Why is it i need the 3 pin plug?
