20vt engine mounts and non starter
(In Topic #115618)
next i pulled the fuel rail out and the injectors all pulse once and then only one pulses. cxhecked the ecu with my friends, fuel pressures good.
any ideas?
ive got the gti mount it doesnt fit, im running the 02j box?
when the engine is cranking over you should have a pulsing signal at the injectors have you tested you have 12v there?? good spark??
do you know what front mount i need?tried a gti one but doesnt seem to fit?thanks for advice
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
if you dont have a laptop then your working blind which is not good
charlesj said
sorted now was the wiring had three wires into one wire and think the resistance was to high, still dont know what front mount with the 02j box?my mk1 had 4 brake lines into the master cylinder, fitted a 16v and its got two, do you need a t-piece or something?getting excited though!
yep mk2 t piece
the mk1 mount will fit this at the front try loosening the two 17mm bolts on the crossmember then wiggle it abit and fit mount :wink:
