20vt custom boost pipe and n75 question
(In Topic #136087)
im using an ARX engine from a golf
so 1st the intake pipe it has a small pipe at the bottom nearest the turbo inlet can this be removed is it for the silly air pump system that ive taken off?
if im using a QPENG managment can i replace the N75 valve with a manual variable boost controler?
the OEM boost outlet pipe has the tails on for the dump valve and a smaller one for N75 valve so if i use new pipes to re route the boost pipe how do i connect the DV and N75? do i have to weld in the tales?
thats it for now thanks
I'm then planning on fitting a manual boost controller between the small pipe that comes off the turbo actuator and the top pipe on the throttle body. This seems to be the way forward from what I can gather from a few of the builds on here.
Your diverter valve needs to be fitted as close to your throttle body as possible, so I believe. I've just got a straight silicone 'T' pipe and fitted my dump valve to that.
The rest of the piping is up to you, I've had a few issues with boost pipes that have to travel under the battery and then over the rocker cover, (the bonnet sqashes one of my pipe joins a bit)!
06 Audi A3 (Wifes daily)
