2.0 bottom end with 1800 head, possible?
(In Topic #96646)
just depends which block you use then,
3a seems to be the ideal as it requires the least messing about.
hth
Chris
Need your console repaired or mods done? drop me a pm
the mk3 blocks metioned are all tall blocks, which iirc are all approx 17mm taller than the 1800 block which may (not everyone gets this) cause the bonnet to foul. the 3a is the same height and is sometimes reffered to as a "bubble block".
afaik every 2l block needs blanking
hth
Chris
2.0 bottom end
Chris
