2.0 block 1.6 head
2.0 block 1.6 head
Hi I was just wondering if I could fit a 2.0 block in my 1.6 gti using the original 1.6 head
Wassup with the existing 2.0 head? What advantage are you trying to achieve with the 1.6 head? As I see it, the fact that one has mechanical tappets, and the other has hydraulic ones, probably means the oil channels are sufficiently different, so it wont work. Also you'll end up with 2 oil breathers or something - which isn't as bad as ending up with none!
I already have 1.6 head which has been port and polished with I cam. so no good then??
Which 2.0 block
Well aim not to shore just wanted to get a bit more power out of it will I need 1.8 k-jet head or will the k-jet system fit on mk3 2.0 8v engine :dontknow:
1.6 gti head won't fit a 2.0l block
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
