2.0 3A engine
(In Topic #85099)
2.0 3A engine
I have just got a 2.0 3A Audi engine, but realised there is no blanking plate in the block for the mechanical fuel pump, do you have to run a external electric pump?
Also these engines are electrnic ignition and my MK1 was on points, do i have to fit the ignition module etc? or can i revert to running on points again?
Will i be able to use my original radiator or will i need the bigger Audi one?
Hope you can help
P.s what size clutch and flywheel do you need to use? as this engine was an auto.
MK1 Series 1 CL 1976 2.0 3A Conversion on Twin 40 Dellorto's
MK3 VR6 3DR Tornado Red
