1993 Mk1 Engine Larger Injectors.
(In Topic #128928)
All it will do is overfuel.
The injection pulse widths will have to be adjusted shorter by the ecu and driveability will suffer.
The stock injectors are more than adequate even on a mildly modified motor.
Its a pointless modification unless youre getting more air in there to burn.
Sorry to be negative but theres no positive point to it on a stock motor, hope that saves you some money.
Website Manager
It is mechanical constant injection system (CIS), all 4 injectors spray fuel all of the time. The metering head alters the amount of fuel the injectors pass based on airflow flow through the metering cone. The pump generates the pressure and the WUR creates the control presure that controls how far the metering head pin moves for a given airflow.
lhasadreams said
Kjet does not use an ECU !!
k-jet wasnt fitted to 93 cars digipants was hence the ecu would need a remap to cope with the injectors :wink:
Website Manager
Im well aware of the differences of kjet vs digifant vs motronic etc.
