16v Running issues
(In Topic #111438)
16v Running issues
Recently finished my 16v conversion and was running sweet, started straight off the key and idled lovely.
Had to replace my fuel lines as one had split, finished that today and started it up……………
After 5-10mins of running lovely it just cut out, i went to restart it and it took a while but then started and now idles at around 3K!
Has anybody any ideas? have to sort this out as i have my MOT on Tues morning
New project - Aero Blue 86' Mk1 Golf 16v Cabby
Pride and joy - Helios Blue 89' Corrado
All the inlet piping seems fine and there don't seem to be any major vacuum leaks.
Paul_c like you say it seems happy enough to idle a 3k its till smooth etc (not that i have left it running for ages).
Possible a metering head issue? this wouldn't be an airlock somewhere would it?
Surly if it ran lovely before it wouldnt be any of the adjustment screws? like you say must be a leak sumwhere
Tried blocking off the vacuum connection from the inlet manifold (the one that goes to the servo etc) - no luck.
Checked gaskets and connections within the inlet manifold assey - no luck
any more suggestions?
nb also now have a vacuum gauge connected and that shows idle when its at 2.5K?
Could this be an ISV/IAC issue? wondering as its the only way for air into the engine without passing through the throttle body
KV84 said
Right, all vacuum lines and connections replaced - no luck.
What's the actual reading on the vacuum gauge, in units of pressure? I can compare it to my idle reading.
Yeah sounds like ISV issue, disconnect it and plug the holes up and see how it behaves.
From that i would think that eliminates a leak after it otherwise it would run and also no leak elsewhere otherwise the leak would supply air?
KV84 said
paul_c just tried that, took it off and blocked air supply from that point on - coughed on the first turn and then wouldnt start at all.
I don't understand - are you saying there is a leak elsewhere, or not a leak elsewhere? I'd say you've found the leak (the ISV) and that its now no longer running because the idle speed and mixture need to be reset to make it run within spec. I don't suppose you still have your AAV do you? Or, a spare ISV, or able to clean/check the ISV you have.
Left the AAV on the old 8v when i sold it
Going to call in a favour off a m8 with a 16v rado and try his
Wouldn't be the wiring would it? surly it wouldn't have run fine for the last 3 weeks if it was (Im no auto-lecy, but my electrics arent bad)
thinking about it when the engine origionally cut out and i went to restart it the ISV sounded different to usual - a smoking gun maybe?
In fact, AFAIK nobody's done a guide to wiring the ISV in but its just a module and a couple of wires?
1/2 through a guide to go on the forum - sort of an add-on for anybody who wants the full setup.Its a little more than a few wires but its not rocket science >> not going to finish and post it until mine is sweet though
It now starts happily enough and idles at 1500 rpm before rising to 2000 after about 10-15s
I suppose really it would be cheating to just adjust the idle - loosing the will now
Seems odd that is was fine and just like that the idle changed.
I got a big box full of orings, it has a size in there perfect for 16v idle screws
To set idle on 16v equipped with working ISV control unit:
1. disconnect red/black wire from coil (if done properly there should be a seperate spade plug with a wire from here to isv control unit)
2. disconnect breather pipe from block and route so only fresh air can be drawn in
3. Allow engien to warm to at least 80 degrees oil temp
adjust idle to 1k rpm, and tweak CO to 2% if you have decent sniffer gear to hand.
Oh and make sure the ignition timing is setup right before you set the idle/co
Have now tested all of the piping to the ISV and the ISV with no luck.
rubjonny PM sent
Has to be an air leak. Can someone confirm my thoughts here:
TB obviously governs the inlet of air into the inlet system
Depending on air demand the pressure plate in the metering head regulates the fuel sent to the injectors
During warmup/idle the ISV delivers air into the system when tb is closed
You could simply disconnect, remove, and block up both sides of the holes?
Sounds like you either have a faulty ISV or the wiring to it is faulty, which means its fully opening instead of doing its job and regulating the idle speed.
Ignore the metering head - it simply measures whatever the airflow into the engine is, and supplies the relevant amount of fuel to make the correct air-fuel mixture. It doesn't influence (well it does but negligably) the actual amount of air flowing, just measures it.
