16v Conversion Woes. Very poor cold running.
(In Topic #140997)
Firstly it runs terrible when its cold. Starts first time but runs really badly and if you attempt to put any throttle on it just cuts out. Once it warms up it runs fine. I've checked and changed the WUR and ICV.
Secondly: Now the timing is bang on but when i try and set up the CO2 the best I can get at 950rpm is 1.45% as any futher adjustment results in lower rpm and the idle screw is already at maximum adjustment and if I try and turn it any futher it will come out the TB.
I'm assuming this is all linked to one issue. The ICV buzzes fine when iginition on. Could the Idle controller be knackered?
Any thoughts people?
Cheers,
Craig.
Craig, Co. Durham
78' MK1 Golf N (Work in Progress)
88' MK2 Golf GTi 8v
93' MK1 Golf Cabriolet
06' Yamaha R6
88' MK2 Golf GTi 8v
06' Yamaha R6
what about Igntion timing? with a timing light
check for any air leaks inc vac lines.
when mine was bad i adjusted ign timing to 7degrees advance then adjusted co - 2.0% and adjusted idle to suit. ran fine after/better adjustment
Saab 93 diesel daily
Website Manager
look all around the engine for split hoses and air leaks, look inside the folds of the inlet boots too they like to split where you cant easily see
I've been doing some work on my MK2 16v today and noticed that the ISV buzzes a lot louder than the one on the cabby.
I'm pretty sure its the ISV controller thats at fault. When I get time i'll swap the one out the MK2 into the cabby and try it.
Craig, Co. Durham
88' MK2 Golf GTi 8v
06' Yamaha R6
88' MK2 Golf GTi 8v
06' Yamaha R6
