16 v conversion
(In Topic #98713)
16 v conversion
what parts can i use from my exisiting parts on the 16v block and head?
i will continue to use my twin webers on the 16 v so can i just get a block and head and use my exisiting wiring and gearbox??
any advice and help from any one who has done this wud be appreciated…
93' cab in need of a miracle
you will need a new inlet manifold for your carbs…
you will need the 16v engine and also the ecu and tci unit plus the wiring loom for this - the loom is small only five or six wires….
or will i need that for the timing side of it all etc?
will my gearbox fit straight on too?
Your gearbox will fit.
i had a slight feeling it wud be needed for the ignition but didnt know if thi cud be overcome.
cheers for your help.
shall start looking for it all.
or is that a common way for this engine conversion ?
mk1nath said
wud that effect the way it runs or anything ?
Ignition advance affects the way it runs, but not drastically - you'd probably not notice a difference, you might get a few flat spots etc. I think the most common way is to reuse the 16Vs ECU, even with carbs.
Fair point tbh
i'm sure someone emailed me a while back about using a saab dizzy as well.
16v on webers… what setup would be best for what engine
1.8 16v on 40's or 45's?
2.0 16v on 40's or 45's?
i've got some 40's kicking around and thinking about building up a second engine (just incase etc) so was wondering whether they'd be best with either a 1.8 or 2L… or whether its worth going down a specific route/setup..?
i'm sure this will help mk1nath in his end result :wink:
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
just that they're kicking around gathering dust, bro's left overs from a half arsed attempt at a project, he's gone for a 20vt now
