1.8T AGU??
(In Topic #119190)
1.8T AGU??
just wondering what cars does the AGU engine comin? is it just the mk4 golf?
and also putting an AGU in can you use the orinal driveshafts, do they fit in mk1 hubs?
thanks
Check here for more info: Qpeng.com is for sale | HugeDomains
The driveshafts are dependant on what gearbox you use, if you keep your original box then its the same shafts, if you change to O2A then you will need either 100mm shafts or to change the output flanges on the gearbox.
Re: 1.8T AGU??
cdh said
hey,
thanks
No they dont but 100mm late cabby ones do with the correct mounts on the MK4 Gear box
AGU 1.8T were fitted to MK4 Golf GTi , Audi A3 1.8T's and some Skoda Octavias made from the start of production in 1997 until 2000.
thanks
Engine mounts can be bought for about £150 for the n/s and rear if you're going the 02a/j route and about £80 for the os mount. I built my own as they're not that tricky to build if you've a few basic metalwork tools.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
foxymk1 said
i have a AGU engine and engine loom for ale if you need 1 mate
A case of speckled hen and a case of bombardier?
8O
mrpurple said
Wiring depends how carried away you want to get, I re-loomed the whole car with a hacked back mk4 loom, way superior to the original mk1 loom, you can just use enough for the engine though.
cheers mate, if i wanted to keep original clock what the best route to take with the wirring?
and is there anywhere that sells mounts? or is it case of looking on forum classifieds and ebay?
thanks
thanks
thanks
thanks
thanks
thanks
Regarding mounts there's usually some on ebay (although not at the moment) and there's always some for sale on the caddy forum (www.vwcaddy.com), i'll be building some in a couple of months as I don't like the way mine are at the moment (room for improvement!), looking at building a few sets and selling them on so may have some for sale then.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
