1.8 kr engine help
(In Topic #139722)
1.8 kr engine help
:dontknow:
finally round the front is the oil filter housing with the brown or blue 0.3bar oil pressure switch (yellow) and the white 1.8 bar oil switch (blue/black)
MK2 loom wont fit directly becasue the fusebox is on the opposite side of the car, unless you manage to find a LHD loom. also depending on your car the plugs may or may not fit. early ceramic fusebox nothing will fit you'll have to make it, later blade fusebox you can use a pre-90 mk2 16v loom just modify the lengths so it fits the mk1 bay. 90spec mk2 has different plugs again so wont plug in.
