1.8 8v GTI Cabby Engine upgrade 1991
(In Topic #142953)
Hope all is well,
I have a slight problem and looking for a solution,
I currently have a 1.8 8v GTi cabby which is running extremely rough after a little bit of tinkering i have narrowed it down to the metering unit which seems to be flooding the engine looking at several posts on here it seems its a common thing.
1. Where can i find a metering unit for the current engine?
2. If i want to change the engine to a more improved one and minimal work etc whats the easiest engine to do this with someone has suggest a Mk3 engine or even a seat Ibiza GTI engine..
Any help and suggestions will be appreciated.
KingKhan GTI
or cheaper source a metering head from somebody breaking a gti? look in breaking car section.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
When you say KR engine where am i most likely to find one of these from what car?
KingKhan GTI
Abf is mk3 gti 16v.
Ha it's cool. I did Kr (well 9a bottom end from corrado.) it's simpleish had mine on carbs. Rebuilt the head so was as new.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
The metering head on the KR engine are these reliable? Looking at forums everyone is always having issues with metering heads?
If i can source a 2.0 litre 8v engine from a Mk3 GTI will this engine slot straight in with minimal effort?
The 16v engines do they take more effort in terms of wiring etc?
I just want to slot an engine into it that uses the existing mounts.
Sorry for all the questions..
KingKhan GTI
Not overly sure on the wiring but on injection, think on Kr you wouldn't need to alter much. I ran mine on carbs so just and ignition loom was needed. Sure I've asked and gti wiring can be used on Kr/9a (9a is corrado engine) but abf is tricky wiring wise but can achieve more from the abf with more ease. Suppose 8v will
Have a lot less on so wiring would be straighter forward I think.
Depends how much you want from the car mate, in my eyes if it's a daily I'd stick with a gti. If you handy with spanners then I'd say a good weekends work will swap it over.
If its not daily I'd take my time and put a nice 16v in there with the leisure that suits.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Personally i just want the easiest conversion with the best results but without future hassle.
Really appreciate your time on replying matey
KingKhan GTI
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Im just concerned that if the KR uses the same system then im in the same boat so may as well stick to what i have
KingKhan GTI
No engine once in will be problem free forever though.
Carbs are ok but thirsty and inaccurate of fuel inlet. Basically balance em and let them put in as much as they can. Again if not daily not a big worry. Do sound nice though.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
