1.8 16v Conversion Questions
(In Topic #124844)
Also what do people do with the airbox as the 16v one is massive and won't fit, looks to me as if a Mk2 GTI 8v one would do the trick?
The water pump pulley - which one are you using? Did the car have power steering? Beware if its the double pulley, one of them (the one you need to work) freewheels so the water pump isn't driven properly! You need the single pulley from a KR without power steering.
The airbox - cut a slot in the base of the Mk1 airbox and sit it on the chassis leg, using the Mk2 induction pipework and metering head (transfer from one to another).
I don't have a Mk1 airbox standard, it was a 1.8carb with a K&N pancake when I got it.
No doubt sometihng else could be cobbled together but the Mk1 Airbox will take the metering head on top quite nicely, needs only a few mods to reposition the breather and fits the gap okay.
The water pump pulley on non-PAS cars is different to the twin pulleys on PAS ones. There's 2 variations of pulleys on the PAS cars though, unsure if both have the freewheeling pulley or just one. Mine did.
But the waterpump also wont turn, due to its double pulley having one part which is connected to the pump (crank - PAS pump - water pump) and one part which freewheels (crank - water pump - alternator).
I think you need to look at the water pump and spin each pulley in different directions, to understand it.
Is the standard 1.8 carb fuel lift pump in the tank going to be ok or does it need replaced for a 16v item, I have the high pressure under floor 16v pump already.
as for airbox i used an early MK2 16v airbox as its narrower, works better than the mk1 airbox if you use the full 16v isv setup as it has the correct pipes on it for isv and over-run cutoff. chop the entire bottom half of it off so it sits low enough, use the 90spec 16v inlet boot as its shallower.
