1.6 GTi Metering head
(In Topic #97867)
2 1983 Campains (concours & track)
1985 Blue GTi Ragtop
2001 Bora Estate TDi SE (very very rare)
2000 Golf TDI commuter
2005 T5 Transporter with 394000 miles on it!
1600 metering head:
Both on a 9A engine, though. It might work out (due to the different VE of the 8V 1.8 engine) that the AFR doesn't follow the above trends, and in fact the 1600 metering head might just make the engine run lean at low throttle/low RPM and go into rich misfire limit (somewhere around <10 AFR) at WOT. Someone would have to do a back-to-back on an 1800 8V engine to be sure!
cos more power is produced, the revs will rise faster (car accelerates faster)
Chairman
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Initial impressions are that it picks up quicker when blipped while stationary
Driving it pulls harder over 3500rpm, not sure if it pulls less below that or the difference is bigger making it feel like it's lost low end power, I will have to do so more driving to see.
would be nice to see some figures and share with the guys :wink:
we're all suckers for whats on paper! :roll:
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
i think pauls was pretty rich up top and on idle
1982 1.8T-20v-GtEfi. K03S. Megasquirt. 16v Servo + MS. Relayed lights. Mk3 Wiper Motor… Getting too Reliable!
With thanks Eddie-Toyotec, Ben-Bens_cab, Brian-Broke and the Mk1 Owners Club! 211Bhp, should get 250 on next map!
Indeed, I had to richen it up by half a turn before it would start!paul_c said
at the very least, you need to measure the mixture and reset it.
Currently the idle CO is 1.5%, do you think I should have it richer Paul?
Ideally you need to measure it at WOT, which isn't going to be possible with a conventional gas analyser. You'll need a wideband lambda probe and a rolling road/drive fir this.
