1.6 8v to 1.8 8v conversion
(In Topic #98024)
Im looking to carry out the above conversion in the near future as my 1.6 is getting a bit tired. Im going to go with a 1.8 head and 2.0 bottom end.
What im wondering is how much of the 1.6 setup I can keep in terms of fuelling/metering and electrics/loom? (I have the older bullet type fuseboard)
Also wondering about which gearbox to use with the 2.0, the 1.6 or 1.8?
Any advice appreciated.
82' 1.6 GTI
Anybody know if the 1.6 metering setup will be ok for my conversion? Would save me a fair bit of hassle.
82' 1.6 GTI
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
the 1.8 gti engine is pretty much a straight swap for the 1.6. the 2.0 belly will need the 1.8 head on it along with a blanking plate over the breather on the block, which the wur will be fixed to and a spacer ring for the dizzy. you can keep all the 1.6 fuelling, igition and box if you wish. 2.0 will rev fine if you cam it, therefor warranting keeping the 1.6 box. i'm sure later 1.6 5 speeds had the same ratio's as the 1.8 boxes anway. easiest and cheepest is a 1.8 engine swap.FriedRiz said
Cheers mate, good to know.
Glad I can keep my fuelling and metering setup, makes things more straight forward as this is my first attempt at anything outside general maintenance and servicing.
Was planning on a cam anyway so well worth it if it allows me to use my existing box.
Last couple of questions…..
Which 2.0 should I try to get, Audi bubble block, Mk3 Tallblock?
Any engine codes would be great.
Will I need to use a clutch to suit the 2.0 bottom end?
82' 1.6 GTI
you take the flywheel and clutch off the 3a and bin them, then fit the 1.8 flywheel, clutch and pressure plate, this then allows you to use your original g/box etc.
if your going to do it i'd definately get a cam in there as wooders says.
Chris
Need your console repaired or mods done? drop me a pm
So my shopping list:
1.8 8v head, flywheel, clutch, pressure plate
2.0 3a bottom end
Blanking plate
Dizzy spacer
Cam
4 branch manifold
Could anyone recommend a cam and manifold?
Kent GS1 cam maybe?
82' 1.6 GTI
it idles quite lumpy, but really comes into its own above 4k.
depends what you want really i suppose, lumpy idle doesn't bother me i just want maximum power at higher revs.
i got an ashley mild steel tubular manifold, they're roughly 140 quid delivered from ashley, i did toy with the idea of stainless steel one but couldn't justify the extra cost. if the mild steel ones weren't up to the job the forums would be packed full of "don't get one of them" posts.
ref the blanking plate and spacer ring, i have both from tsr, i would see if anyone on club gti also does them, as the spacer piece i got from tsr doesn't have a groove in it to mount a seal, as a result i'm now getting oil weeping from around the flange. i remember reading soemone on there did the rings with the groove and a seal.
just a bit of hindsight that i wish i'd done.
ref the head, i'm running a solid lifter head on mine so this requires the gaps between the cam lobes and the tappet bucket setting up to a certain tolerance by using different sized shims.
when i fitted my cam i had to replace about 5 of the shims to get the gaps right, the problem is some of the sizes are now like hens teeth and i ended up having order one from a dealership on the isle of wight!
so if you are shopping for a head (in hindsight again!) i would suggest you look for a hydro tappet head, the later mk1 gti's and some early mk2 k-jet's came with dx engine codes with hydro heads. (you don't want pb head as this is digifant came in later mk2 golf 8v's)
these auto adjust to whatever the gap is, so no shimming required, and will save you extra messing about trying to get the gaps right.
the 3a bottom end will have run a hydro head on it to begin with so the pump will be able to cope with another hydro head so no worries there.
obviously make sure you get the correct cam for the head as the solid and hydos are different.
anything else you want to know just ask mate, i got plenty of guidance so am happy to help.
Chris
Good heads up on the spacer ring and head too, nice one.
Just planning at the moment and will start picking things up as they come available.
Thanks for your offer, I will give you a shout 'when' I get stuck!
82' 1.6 GTI
wouldn't bother with the ashley manifold, but i would heat wrap the standard one.
Cheers wooders, why do you say that?
Whats the best product for heat wrapping?
Plenty to think about on the cam front.
82' 1.6 GTI
So does the 1.6 manifold match the 1.8?
82' 1.6 GTI
82' 1.6 GTI
