1.4 16v into a mk1?
(In Topic #109137)
1.4 16v into a mk1?
if i do this how much of the engine electrics would i be able to junk and wot distrubutor would work and wot would i do about the vacuum advance? and will the polo engine line up to the small block mounts? seriously any help will be amazing!
planning on buying a polo 16v donor car so wot bits should i salvage?
<a href="http://s398.photobucket.com/albums/pp63/JoeMk1/?action=view?t=sig3.jpg"><img src="http://i398.photobucket.com/albums/pp63/JoeMk1/sig3.jpg" border="0" alt="Photobucket"></a>
The flywheel needs swapping with the 1.3 one as the 16v one isnt compatible with the 1.3's gearbox. (The starter motor doesnt turn it) You cant use the 16v gearbox because the driveshaft flanges are different.
The alternator pulley needed changing as said^^, but also needed shimming out so it was level with the engines pulley.
He saved messing about with ECUs and fuel injection by fitting bike carbs, so i couldnt offer any advice about that unless you did the same.
Apart from that its just the standard 5 speed gearbox mount fabbing (if you choose to fit one) that needs doing.
also if i chose to fit a 5 speed box would there be any messing about with the gear linkages to make it work? thanks for all the help that last post has realy cleared up some of my worries
A couple more things, if you're using a five speed 'box the rear box mount will need a little notch cutting into one side of it to fit, you'll see what I mean when you try n fit it.
Also only 2 of the 3 bolts for the drivers side engine mount can be used on this engine.
These are not even worth worrying about tho. :wink:
He managed to get in the 14s at santa pod at the weekend.
Apparently the 16v flywheel and starter ARE needed when using the 1.3's gearbox.
Apologies!
what do people think?
