Winter washing?
(In Topic #119471)
Winter washing?
My '83 GX is pretty mucky at the mo' having had a trip over the Pennines on the M62 (salt!). The thing is its really cold out and I'm not sure if this is a good time to clean it or whether I would be better off waiting for a warmer & drier day.
The car has recently been resprayed and I don't want to risk ndoing all that hard work - on the other hand if cleaning it in temperatures around freezing is going to cause its own problems then I'll leave it.
Any advice most welcome.
Damon
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
millfischk69 said
i would say wash it a.s.a.p as the salt will cause body work to rust alot quicker than clean water will.
agree with that
i washed mine once and it was re-freezing as i rinsed down - just becareful as under thecrud you could scratch - so blast with hose/jet wash first then maybe use soft bush instead of sponge etc
but get the salt off asap - i wash cars probbaly 5 times more in winter than i do in summer
T
edit: tian dont use hot water it dissolves the salt into the water quicker.
T
guess we all have our own methods that we use aye.
I used the hottest water I could bear to handle (having headed out before reading novocaine's post) and then rinsed off again with the hose before buffing dry with the leather. I hopefully got all the salt off.
Cheers for the advice - I need a nice cuppa!
Damon
And then the next day its filthy dirty again.
I'd wait until this cold spell is over.
Member 125 - 2005
…give it a good polish .
i seem to remember i used a polish called collunite ?? . it gave it good protection against the elements and when it got dirty a blast with the hose , the dirt just literally dropped off ..great stuff to use .
I am thinking of just hosing it off with cold water (especially under the sills and wheel arches then sticking it back in the garage (not heated but dry).
I suspect the garage temp will drop well below zero in the night but surely a bit of frozen water on the underside is better than leaving salt on the car - isn't it?
- Drive to local IMO
- Asked for super wax
- Pay attendant
- drive car into machine
- leave with fresh waxed and dried car
:wink:
~Madferret
Mk1 1457cc 5door GX '83
I do the brakes all the time now, even just after rain let alone gritty snow. I ride the brake a bit when I'm nearly home to get them steaming hot just before I get back to the garage, then the discs dry off straight away, good if it's gonna be sat there all weekend for example. Stops them goin manky?Bert said
if the roads are dry,take it for a spin round the bloock,dry the brakes and the body off where the leather dont reach :wink:
Bert
Marc
- Pay attendant
:wink:
You'd be surprised at how much damage car washes can do to cars. I used to work at a petrol station and the brushes would literally lift the cars up off the ground, cars were wrecked in there! Apart from the damage caused the machine also stopped working whenever temps were low as the machine and brushes froze up.
Petrol station jetwash machines are much better - but try not to use the brush, and if you do then blast the brush clean with the pressure lance first.
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
