Why are previous owners all idiots???
(In Topic #100210)
Managed to get home (by this time I had no clutch!) and on examining the car it appears the gearbox is separating from the engine at the front 8O
Bolts missing everywhere! The most major of which is the one on the bottom of the starter motor and one of the ones on the top that holds the gearbox to the engine.
Looks like a job and a half is going to be involved finding some bolts. Not to mention potential damage done to the clutch/flywheel/ input shaft bearings from it running out of alignment.
I know the car had a new engine before I got it, but what was wrong with putting all the flippin' bolts back in!
Clowns
Happiness ain't at the end of the road.
Happiness is the road….
When i bought my car (rivage) it was a bit of a wreck and the guy i bought it off said 'it dosen't run properly i think the engine is wrecked but i am no mechanic!' with one look at the engine i noticed he had the ignition leads going to completely the wrong spark plugs they where strecthed and almost pulling dizzy cap off!! I went to see the car with my bro (in the clipper) we agreed a price the car a bargain (as engine was wrecked lol) nipped to local VW garage bought new ignition leads popped em on and drove the 2minuets away to my house car has been perfect since!! so sometime crappy previouse owners are a god send!!
Crazyquiff could probably sort you out with some bolts
I know what you mean tho about previous owners tho, had a few bodges in past, one was main engine bolts shoved into holes with silicone instead of nuts on other side 8O 8O
must have pulled hundreds of the things out the car by now!!
had them on every classic Ive ever had! why not just fix it properly?!
Miles of badly wired spaghetti is my other pet hate! And why does nobody use long enough wires? They always have to cut them 2 inches too short and stretch them!
Anyway, in other news;
After dodging torrential downpours; searching around in the shed and garage and raiding the spares London Taxi; I managed to find enough bolts to get the box back with the car again.
It seems it was held on by 1 bolt in the top of the starter motor and one bolt on the top of the gearbox! How it never came apart before I'll never know. The bottom starter motor bolt is also goes into an engine mount so that explains the judder that used to occur if you set off too quick in first.
Just tested it and it drives fine and no judder. Half the bits of clutch cable mounting were also missing so I took the opportunity to fabricate a rubber mounting from a Ranger rover shock absorber bush and a small piece of tube.
Hooray for all those odd bits and pieces I keep in various drawers/ ice cream tubs
:mrgreen:
the one thing u can never bodge/quik fix is an exhaust always has some way to brake ur temp fix!!
and the heatshield for the exhaust manifolfd appears to be a 5mm sheet of steel also… great :roll:
theres plenty more i know, but they slip my mind why wont people fix stuff properly :evil:
1983 Golf 1.3 Driver:
BODGENEERING. :wink:
Black MK1 GTI Campaign SOLD
Blue T5 GP 2010 Transporter (Van)
Orange M6L 2012 Brompton (Bike)
Neversummer 2012 Revolver (Snowboard)
'expert and skills trademan in BODGENEERING'
It sometimes amazes me, the lengths people will go to in order to not do a job properly!
There was a reply to a post on the Bedford CF forum, where I was talking about welding on my van, and someone actually said they'd repaired their chassis with bits of cereal packet and some Chemical Metal.8O "passed the MOT, much cheaper and easier than welding and just as good" was the advice. Until it crashes it and snaps in half…….
:roll:
1989 MK1 VW Golf GTi Cabriolet, 'All White Edition' - currently having a new blue roof fitted. Yes it's not white but it requires less Cif to clean
in the 3(almost 4) weeks i've owned it, the car has developed 2 fuel leaks, spurts splutters and dribbles its coolant everywhere as soon as its at a good temperature, there are bolts missing all over the show and the bolts that are there are invariably the wrong ones(rocker cover was held on with a carraige nut(the square ones used for wooden fencing!)), oh and the choke does'nt work and i think the cylinder head is knackered and the block has a nasty scratch inside cylinder no.4…
The list is sadly still growing, but, even with all that, if the previous owner had told me what was wrong with it i probably would have still bought it, because of the aforementioned good bits, it just would have been nice to know what he had tried as regards fixing the engine as its had work done recently. my family say sell it, my neighbours say sell it, my friends say sell it, my head says sell it, my heart says otherwise…. :roll:
1991 Diamond silver 1800 16v Corrado 'Betty'
Gone, but not forgotten;
1985 Lemon yellow Polo coupe S
1983 Gambia red Golf C
1983 Diamond silver Golf GX
1981 Mars red Golf GTI
previous owners suck. sometimes you get one that has taken good care of their cars. like the PO of my Caprice Wagon. no problems with it at all.
MK1Dubs.com
#655321
93 Passat GLX, 90 passat GL WAGON,90 jetta GLI, 81 sportruck, 81 scirabbriolet , 79 Rabbit L 4dr, 79 whisper blue rabbit 2dr
#655321
