Which 3 clocks should i have in the centre consul
(In Topic #152787)
Which clocks should i have .mine has a clock , oil temp,and an amp meter .its a 1981 gti.1.6
Cheers russ
Cheers russ
The three clocks weren't standard, but typically you see fitted what you have there, or oil pressure
Iv'e got a volt meter,blank in the middle & oil pressure. The common choice seem to be these two plus oil temperature, but i didn't opt for that one as that's more for the higher specs & GTIs. If i were you id bin the ammeter as there just a fire hazard waiting to happen as the full electrical load runs through a tiny gauge, plus a volt meter is more useful and more or less does the same thing
Chris
Chris
