what would you pay for this
(In Topic #89904)
i am thinking of selling my mk1 but i trying to find out what its worth
it has just had an major restoration with no expence spared
i also have a carrier bag full of recipts covering nearly the past 20 od years
here is a list of just some of the new parts fitted
new body parts
l/h wing
r/h wing
full front panel and crossmember
bonnett
l/h sill
r/h sill
l/h rear wheel arch
r/ rear wheel arch
r/h rear chassis section
rear valance panel
bodywork and moulding clips
windscreen
tailgate decals
side decals
new components
l/h wishbone
r/h wishbone
l/h front wheel bearing
r/h front wheel bearing
l/h complete strut (bilstein)
r/h complete strut (bilstein)
front strut bumpstops x2
brake master cylinder
l/h front caliper
r/h front caliper
l/h brake disk
r/h brake disk
front brake pads
l/h rear strut (bilstein)
r/h rear strut (bilstein)
l/h rear top spring cup
r/h rear top spring cup
l/h rear brake drum
r/h rear brake drum
l/h rear wheel bearing full kit
r/h rear wheel bearing full kit
l/h handbrake cable
r/h handbrake cable
rear brake shoes
brake shoe fitting kit
door pins x4
door hinges x4
rear roll bar clamps x2
rear roll bar clamp clips x2
rear brake compensator valve
wishbone kits x2
wishbone rear mounts x2
goodridge brake hoses
steering columb gaitor
engine mounts x4
gear linkage kit
clutch kit
metal water pipe
speedo cable
crankshaft seals
inner cv gaitor kits x2
outer cv gaitor kits x2
brake pipe and ends
exhaust rubbers x4
alloy strut brace
new engine parts
timing belt
timing belt tensioner
spark plugs
k+n sports filter
fuel filter
oil filter
stainless 4 branch manifold
janspeed exhaust
head gasket set
large crankshaft oil seal
small crankshaft oil seal
valve springs large x8
valve springs small x8
main bearings
big end bearings
bottom end gasket set
water pump (full kit)
thrust washers
injector seats x4
starter motor bush
new body parts
l/h wing
r/h wing
bonnett
l/h sill
r/h sill
l/h rear wheel arch
r/ rear wheel arch
rear valance panel
windscreen
tailgate decals
side decals
new components
l/h wishbone
r/h wishbone
l/h front caliper
r/h front caliper
l/h brake disk
r/h brake disk
front brake pads
l/h rear brake drum
r/h rear brake drum
l/h handbrake cable
r/h handbrake cable
rear brake shoes
door pins x4
door hinges x4
wishbone kits x2
engine mounts x4
gear linkage kit
clutch kit
metal water pipe
speedo cable
crankshaft seals
brake pipe and ends
exhaust rubbers x4
alloy strut brace
new engine parts
timing belt
spark plugs
k+n sports filter
fuel filter
oil filter
janspeed exhaust
head gasket set
main bearings
big end bearings
thrust washers
injector seats x4
starter motor bush
Alan, I can't believe your selling her, she's beautiful…. 8O 8O 8O 8O 8O
Anyone looking for a cracking example of a mk1, would be hard pushed to find a better one.
Having seen her in the flesh at the first ever scottish meet I can certainly vouch for how good she looks.
Can't believe your thinking of selling, just as well I'm using the keyboard as I'm speechless… 8O
what would you pay
come on guys some feedback would be nice
First off let me say I like that a lot, got to be my favourite GTI colour
In regard to value well its always difficult to comment when you havent seen it in the flesh so to speak but I presume this was a bare metal full re-paint aswell….was the inside done also?
I would say looking at the pics and reading what youve replaced around the ?3800 mark but its always the same question - it depends what any potential buyers will pay 8O
see here
http://www.pistonheads.co.uk/sales/216991.htm
Is it really worth that :dontknow:
see here
