What should my fuel cap look like?
(In Topic #100284)
Hope that helps…
1982 1.8 GTI Mars Red
http://volkswagenstick…dex2.php?cmd=search&cat=7
Bottom one. :wink:
Yradave says relax.
07792646786
07792646786
when you take yours off, do those black bits in between the points come off too?? Or is that a separate piece of trim underneath
OK, I think I'm getting what you're saying. The bit underneath [or in between] the points is trim. When you take it off, it's just the point of the stars with nothing in between.
Sounds like the bay is right, could be you're missing trim then? :dontknow:
yradave said
There's a black sticker that goes over the screws that hold the filler pipe on.
Bottom one. :wink:
thanks for that - i need one of those as mine is coming off!
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
If your car an '83 driver by any chance?
Yradave says relax.
07792646786
07792646786
Steve_Matthews said
My Mk1 Driver had the same sort of fuel cap where the indents of the star had plastic behind that was part of the cap.
mine doesn't :?
1983 Golf 1.3 Driver:
yradave said
A GX should have the cap with the springy arm going over the key hole, same as campaign filler caps.
Do you know the VW part no. for that?
Crazyquiff does them, though.
http://www.golfmk1.co.uk/FuelCaps.htm
Yradave says relax.
07792646786
07792646786
Cx
