Welders, can you help?
(In Topic #121097)
Hi. Would it be possible to cut a gear stick into two pieces and then weld it together so the upper piece leans toward the driver at about 30 degrees?
I have arthritis in my elbows which restricts movement, about 90 degrees of bend as opposedf to 180 and I am having to reach to change gear which is rather uncomfortable.
If it is possible could any of you guys undertake the task for me, you would of course be remunerated at what you thought was fair.
Thanks Sean
Thanks Sean
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
yea dont cut it into two peice just cut enough to bend then weld back together if you wasnt so far i would do it for you m8
Welders
Sean, my other half Nikki ( NikNaks123) has arthritis like you mate and has suggested contacting remap who specialise in any mods, home, car etc. Might be worth a look mate, here's the link. Hope this helps Stu & Nik
http://www.dppi.org.uk/journal/64/resources2.php
Yo Sean
It shouldn't need cutting - I'm sure your local garage or bodyshop can remove it and bend it while you wait for the price of a pint - it just needs a bit of heat from an oxy-acetylene torch on it. You can then drive your car home, take it out again, clean it up and refinish it with Satin Black aerosol paint (Hycote or Plastikote).
Looking at my GTI gearlever, methinks it can be bent at about 2.5 to 3 inches below the knob and still poke out above the boot.
If you do cut it, you might consider extending it a bit also if it might ease your problem. If so, I'd drill down the exposed ends and fit an insert with spigotted ends: that way you'll retain a bit of strength and concentricity in the joints. I too am too far away to help - unless you could get a replacement to keep you mobile and send me yours to fix it (I don't have oxy-acetylene but I know someone who does!)
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
id do it for you foc probably to far away though :dontknow:
rob
www.keets-customs.co.uk
How's about using something like this -
They're normally used on campers but might help you out……
Anyway, here's a link - http://www.justkampers.com/shop/type_2_bay/type-2-bay-original-vehicle-parts/clutch-transmission/gear-levers-linkage/gear-stick-extension-m12-threads-j13457.html
Spence
Spence
'84 Oak Green Tin Top GTI.
'84 T25.
'68 Bay.
'67 Beetle.
Swansea VAGabonz third Monday of the month.
'84 T25.
'68 Bay.
'67 Beetle.
