Tell me its not only me !!!
(In Topic #108036)
So first thing that happens bolt shears in the water pump…decide to buy a new warter pump, wait for that to arrive and come back to it later.. make a start on the top mounts..takes me nearly a day to get the the mounts off and the inserts out, nothing would shift the nut at the top and then nothing would shift the insert, eventually get them out only to discover that one of the springs has broken…order new spring…ok back to the water pump..remove old pump…go to remove the alternator..guess another bolt shears !!!…lots of cursing…go to remove the pivot bolt only to find its spline and rounded off and will not move…eventually get the alternator moved up enough to get access to the water pump bolts…loosen these off praying nothing else breaks..only to find i cannot get the damn hoses off the water pump..they have some stupid damn clip that i cannot get off…
So started Tuesday now Thursday evening, have one side with new top mounts etc..water pump still attached to engine by the damn hoses..one sheared bolt in the top of the alternator and not even begun on the gear linkage..
Back to work next week and need the car to get me there…need my luck to change.
It's all worth it when everything is fixed and back together agin though.
Except you know in the back of your mind that you encountered several other things to look at at some point in the future whilst fixing the last lot of things and the joy starts all over again!
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
funk-star said
Get some water pump pliers for the hose clips, or mole grips.
was just goingt o say the very same
I always use water pump pliers for undoig those water pipe hose clips
dont loose faith tho mate.. You'll get there
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
took the cover off and there is petrol everywhere
after tightening all the jubilees near the fuel pump its still peeing out everywhere
probably at least another week before I get to go for that drive
~Madferret
Mk1 1457cc 5door GX '83
