Swimming Pool in my Drivers Side footwell!!!
(In Topic #118109)
If so, it'll probably be blocked drain holes/ tubes.
Also try the drain holes in the scuttle pannel.
1982 mk1 golf c 1.1
2002 audi tt 225 quattro s-line
water in footwell help.
Re: water in footwell help.
real-drivers-drivemk1s said
ive had this problem last winter, i found it was leaking from the sunroof down the headlining and A pillar post the into the little void in the bulkhead (between the footwell and bulkhead). If you pull back the carpet and soundproofing to bare the metal etc then there will be holes in that little void coverd by the origional sound proofing. I punched one of these through and blow and behold it was full !!! of water . In that void there are drain holes for the water to escape if ever it gets there but vw has kindly not spared with the cavity wax and then that gets warm over the years it runs to its lowest point and bobs your uncle will enevitbly swamp those holes. Check it out and tell me what ya got. good luck mate.
Its a soft top. It was raining the day i bought it but it dnt leak then. could the door av droped?
It's a cabby….
MK1 16v on twin 40's + my name's Stewart
Member 125 - 2005
UPDATE
It's either the header seal, or the main door seal.
Try turning the hook on the lock handle 1 turn tighter.
