Stiff tappet?? 16 valve
(In Topic #151715)
are you ment to be able to press the tappet or is it ment to be stiff?
engine runs and sounds fine so im sure its not the valve and i did use some shity oil and abit of sludge went in there so not to sure if that might of blocked some up.
i drained the oil put new oil in there. i will run the engine till warm but was thinking maybe i should take them out and clean them….
also oil pressure is fine. cheers doesnt sound like the bottom end either lol ah well
