steering column splines
(In Topic #145083)
I just bought a steering wheel and boss kit for my mk1 however the splines are too big to fit my column which I think is 17mm ? I do have a spare column which has I think 30mm splines, Can someone tell me on the larger column is this just an adaptor that is fitted over the smaller type splines and could I remove it and put it on the column which is already fitted on the car ? Thus giving me the option of fitting my new wheel ? Also are these adaptors easy to remove ? is it just the metal part I need to add or is there something else and do you just tighten the nut down to push it into place? I know im asking a lot of questions but any advice would be much appreciated, Thanks in advance guys, Cheers Carl.
Also breaking a Mk4 GT TDi (LP3G Red) AHF code
I also have a 79 Escort it only has a couple of sticky pages!!
It dunt fit
Then you need plastic spacer from vw from early car.
The part number is in one of my posts. Ill have a look.
Hope this helps.
