rear wheels
(In Topic #124571)
rear wheels
got a slight problem with the wheels on the car. im running alleycats with 175/50/13.
my problem is the rear wheels poke out a little but a little while ago i noticed that one side started to stick out more than the other?
havnt got the wheels on the car atm but this is what they were like just before i noticed they changed
other side now sits abit further in and the passenger side sticks out more.
any ideas what i need to do to sort this?
sorry if its something easy but im a total noob to this
thanks
If it where mine I woud do nothing but up to you
there 7j and an offset of -7
wasnt sure if it was the bushes that needed replacing or something similar?
thanks
ChrisRivage said
the law refers to the tread not the wall
Are you sure?
he wants to know why one side has more poke than the other side
unfortunately i dont know why
n paul yeah as long as the tread is under the arches its fine
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=73039&highlight=
Could be as simply as the wheel arch being fitted differently
Does it drive OK? Have you had any alignment done to verify they are lopsided?
spoke to a guy down the local vw and he said it may be something to do with the axel like the post above but not 100% sure how to check this?
he also said it may be rear beam / axel bushes that have worn out and is causing it to move oneside more than the other?
any help is appreciated atm as i wanted to see if i can get it sorted before the wheels go back on
thanks
For example - someone on here had a similar issue and it turned out he'd not bolted the wheel on properly.
will try and take a look when its not raining and report back
