Photo Request: sorry to be a pain
(In Topic #118723)
Hi all
im currently running a gti slammed on hot tuning coilovers but i really interested in eibach and koni setup.
i know its alot to ask but if anyone would be kind enough to post pics of their cars running the eibach/koni setup i would be really grateful. thanks. im just wanting to get an idea of what my golf would look like.
thanks again
tom
thanks again
tom
The height you set it at will dictate how it looks mate - if you set them the same height as the hottunings it'll look exactly the same.
Hottunings go down 120mm, most higher end coilies don't - i think 80mm is more common.
Thanks but I'm abit confused still! The eibach pro kit with koni dampers are not coilovers so isn't the height they are the height you get? No adjustment!
I'm wanting a good sporty ride but with abit of lowering over standard!
they will be a set height yes but will be probably 40-60mm or so lower than standard setup. varies between each make etc
Thanks, would people recommend the eibach springs with Koni adjustable dampers?
There's two choices I'm torn between, the one above or some fk highsports. I'd like the fk's so I can get the ride height I want but I want a good balance of sporty ride and lowering!
