Petrol smell
(In Topic #154250)
Just purchased my first mk1 cabby, it's great! Just one problem, the car is parked in my garage and when stationary smells a bit of petrol. It only smells outside of the car not at all inside. I have looked at the filler tube and petrol lock which is all new, the rubber tubes to the tank and jubilee clips are all great, no dripping petrol etc no leaks under car! Can anyone help?
I think they're the same on cabbys as tintops? Under rear seat there'll be a round, metal cover with three screws in. Remove this and you'll see the sender on top of the tank.
See if you can smell fuel in the area first before removing the sender - without a replacement O-ring to hand I wouldn't take it out just in case removal ruins a perfectly good one! It's some years since I bought one from VW for only a couple of quid, I don't know if you can still get them or not.
I hope that helps
If you're lines are dry and there's no drip patches (remember these will evaporate quickly, so best to look while it's under pressure with the engine running).
If it's your first cabby… or even your first old car… Could it be that you're just not used to the smell of old car? Old engines are a lot smellier than modern cars!
My garage smells like petrol and I love it.
Last edit: by Mogs
Part number is 113919131A. Just enter in the search box and it will pop-up
Having said that, my fuel pipe in the engine bay is perished a bit so I've got to change that.
