one last drive before winter....fail!
(In Topic #129116)
One last drive before winerising My Campaign…..sounded like a great idea….
started fine after two months in the garage, left it to idle for about 15mins then took it for a spin
It started to backfire and kangaroo about 1 mile into the drive, I pulled over and the idle was spot on, but when I gave it some revs it just popped/backfired and tried to die. I managed to limp it home in 2nd gear…really slowly then it just died on the driveway. Now it refuses to start.
- Undid the fuel filter(only two months old) and it's getting plenty of new/clean fuel ok….and that's about as far as I got as the battery died and it got dark…and it's tooo cold to start striping things tonight!
- Apart from making sure there is a good spark from each plug…any other obvious golf traits to look for?
- It is kept in a garage so shouldn't be a damp problem…
The only other thing I can think of is I left it to idle on quite a steep incline (back sloping down steeply) ….so maybe as the tank is fairly low on fuel it has sucked up some shit as it was on such a steep angle?!!
Thoughts please! :dontknow:
mk1 golf gti campaign
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
i had this on my 1.1 and that seemed to be the problem..
booze and boredom, the greatest mix
hummmm…
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
I want to say it feels more like fuel/timing/condenser/injection….sort of flavour!
I need to check the sparks really!!
I could well be wrong though.
Keep em coming…..
thanks
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
Re: one last drive before winter....fail!
Hi
fill the tank , being involved in a few posts lately where lack of Fuel or Fuel that is past it sell by date has being the source of the problem
baz
yeh, maybe, it shows over quarter of a tank though, and the fuel is only a few months old. also it has a fairly new tank and filler neck (about 3 years old)
I hope it is a fuel issue though and not something more £££
I will stick a jery cans worth in in the AM and try a fresh battery, check sparks….and cross my fingers!
I love the sh*t out of my golf, but it does try my Patience some times!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
I will try to find said hole in the AM…what side? more pointers please.
hummmm…yeh, dirty lines starving the engine of enough fuel was my first thought..
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
The Mk1 Golf Owners Club
should help you out, it's worth checking anyway
There is (should) be a little gauze filter about the size of a large thimble. This catches any large debris before it goes inside the pump. I had exactly the same symptoms some years back. Car played up for about six weeks. Ended up this filter was full of grit, sand, crap, you get the picture…
Cleaned, re-inserted, re-assembled and all was well!
Edit to add, exactly as pictured is chudd's thread, as linked in the above post! :wink:
My Build Thread
if she doesn't run today I will try to have a look at the tank insides and filters/pump etc.
when I took the fuel filter off this morn and turned the key the pump produced a lot of fuel at the union (filled a large spraypaint can lid in about 2 secs) so it's getting fuel ok, maybe it's not enough though, or maybe the block is at the injection side now? possible?
nice1
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
had a quick look at lunch….zero spark
may be the Coil as it died slowly/on off…could be the HT lead from the coil - dizzy.
I'll get the voltmeter out later.
who wants to take bets on what it is?!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
mk1 golf driver
mk2 polo coupe
m2 golf gti 8v
T4 Van
and 26 others!
its an old trick lol.
could be that, or like you said, the coil..
dont rule out the Dizzy cap , i have had the carbon thingy in the middle simply snap off on non-german caps.
baz
