need advice regarding mk1 golf gti
(In Topic #110239)
Re: need advice regarding mk1 golf gti
carbreakerman said
does haveing a glass sunroof devalue the price of a mark1
depends on the sunroof
If its factory, then it shouldnt effect the price..
If its an aftermarket one, them most people would be put off by it.. I personally dont like sunroofs so would avoid them.. But i guess its down to the overall condition of the car and the rest of it..
But replacing it, how do you plan on doing it? as welding in a section could warp the roof…
If your going that way then get it done properly… it seems your looking to sell straight after if you're worried about the re-sale value? :dontknow:
carbreakerman said
the painter as asured me that i will tell he,s going to wheld a steel plate and bars to strenghen i just wonded if any others members had carried this out but once it done i will not sell as the car is like new underneath never seen a weld which proves how well built mk1 realy are 28 years old and still the same sills the sunroof is the only thing wrong
Well good luck with it mate and let us see the results :wink:
You will 100% see the filler in there, even if it is done very well i would still be able to notice it had been filled.
Buts its your car and your choice
Cheers Kenno
Old sunny Out:
Plate welded in (tacked inside and out). Roof support section added (courtesy of a mk2 in the local scrappy)
Skim of filler/touch proxy:
Wash:
Red oxide:
Touch more sanding and filling:
Primared/job done:
The pics don't do it any justice, but you really cant tell the sunny was ever there. I got a long way before paint goes on to show you the finished result, but roof lines are pucka. If the guy taking the job on is any good you should be ok.
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'93 GTI Sportline
Mk1'82 2.0L 8v
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
funk-star said
Bet you notice when its painted ;-)
Ha Ha, thanks for the vote of confidence. Guess will see once painted….but not for too long as going down the retro vinyl route :wink:
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
