my mk1 keeps splitting hoses!!! aghhhhhh!!
(In Topic #126071)
got there, turned engine off 'BANG' smoke/steam came bellowing from my engine.. investigated and found that the water pipe that comes out of the block into the heater matrix had split about 3 inch! knackered. so im stuck at bugjam and need a hose, ended up getting a pal to bring me my spare as he was coming to bugjam too. (thank god) fitted new pipe, antifreeze etc.
driving home, get 2 miles from my house, 'BANG' same thing different hose!! this time its the large one from the top of the rad. why??????????? is it simply cuz my hoses are standard and old, so replace them with silicome? or is there an underlying problem???
I HATE CAR & SCENE SNOBS
thats showing theres too much pressure in the system from the cylinders.
check for a yellow substance in the oil AND you could open the water bottle and check to see if theres oil in there.
sorry to be the potential bringer of bad news mate
booze and boredom, the greatest mix
Oy other thing I was told was that maybe one of the lines in the block could have cracked but I'm no expert so unsure if it's going to mix again or hopefully new hoses new oil cooler better radiator control/cooling and another good flush through should resolve it
it's nice and long though for my 2.0 16
MK1QUINNY said
I know how you feel mate i had the hose off the block to metal pipe split then few weeks later on the big fat tour another hose split which we repaired with super glue and gaffer tape did the job to get us home from scarborough, i have just got all nw hoses bought to replace them all as inside they looked old so presum the rest will shortly catch up, i would say just replace all your hoses for new ones if you dont know how old your current ones. Im no mechanic so dont know how to answer if theres an underlying problem i was concerned too but everything seems to be fine so starting with the replacement of hoses
hi
where did you buy a full set of hoses ? are they standard ?
baz
thanks
ive yet to found a place that sells a full set of standard hoses for a mk1 tintop . I would like to replace mine but not with samco shiney hoses
baz
e I will need sourcing or making
Cheers,
Josh.
ill get some silicone hoses and see what happens,
Feel the thermostat pipe hose near where it connects and also further along it, if it's colder in the middle and away from the thermostat housing then it's a sign of an air lock as the water isn't travelling all the way through the pipe.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
them silicone hoses. hopefully problem solved..
