My engine bay... (from zero to hero)
(In Topic #89474)
______________________________
Now in July 2007 after a complete engine rebuild to name just one of the many things that have changed since then…
I wish… :roll:
_________________
Here she is….
As usual, comments welcome… :wink:
Mint MK1 Wanted PM me
Looks fantastic!!!! :wink:
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
always nice to see a clean bay!
rebuild in progress....
looks great.
As you saw at Stirling, mine could do with sprucing up too….
reckon it'll take me a lot longer than you however :wink:
It's like that C4 prog….10 Years Younger
DubPartz
Member 125 - 2005
Did you rebuild the engine or just paint on outside?
Oil pump went last year (and subsequently lost oil pressure and big ends went smash!) so was forced to completely rebuild the engine. Rebored, new pistons, head skimmed, new valves, guides, seals, oil pump, water pump, the lot.
mk1jim said
top work, did you remove engine or work around it ?
When the engine was out getting its second lease of life, the block was painted, the rocker cover and cylinder head painted, but that was all. Everything else was restored with the engine in situ. (alternator, oil cooler, inlet manifold, brake servo, master cylinder, metering head etc.
dubstar74 said
where are all the in between pics????
Coil ready to go back on after being sanded down and repainted…
Oil cooler off the car…
Oil cooler back in place all shiny. (hadn't done the radiator attachment brackets yet ops: )
Brake Servo and master cylinder ready to go on…
All important radiator cowling to front panel (courtesy of 'dubboy' -many thanks!)
Just to double check one thing, as I had a scary moment a little while back - did you get the rocker cover shot-blasted, and if so did you mask off / clean out the breather?
Rich
mcscrew said
That's really impressive - as said before it looks like it just came from the factory 8)
Rich
thanks Rich. much appreciated.
well, when I say painted the rocker cover, I really mean bought a brand new one And yes, dont worry, very clean. I remember steve mathews always going on about how the breather was a big (largely unknow) problem with early VW's.
I notice you're dipstick is the later type, is this an addition by you? My '83 has the one harder to get at as its much lower in the bay.
Ross said
Superb job mate, looks awesome 8)
Yes it was. When I was looking for a brand new one, this is all I could find. Will be replacing it eventually with the smaller one.
Thanks for the comments mate.
