mk1 golf cab 1.8 gli 1991
(In Topic #97044)
regarding the weights of the vehicle to register in France.
the sticker off the door pillar is missing which should have the weights on,
any body got the same vehicle and could tell me the weights?
they are listed as
1/
2/
3/
4/
the vin plate is German and only shows front and rear axle weight
and I think unladen weight.
car is 1991 1.8GLi cab
manys thanks.
David H
I have a 91 GLi 1.8 French cabby. I can look for more info if you can tell me where I can find it. Not even sure if I have the original book the car came with. I dislike this car immensly and wish I had my Rivage back :O(
<img src="http://i35.photobucket.com/albums/d186/Missmoopants/Golfskissing2.jpg" border="0" alt="Two lovely Golfs">
The_Chocoholic said
Um, what's the question (insert dumb girl look here)?
thanks for replying
the information i need is on a silver sticker that should be on the drivers door pillar or could you look on your carte gris it might be there
it is the axle weights and laden and unladen weights i need
cheers ,david.
Half load: Front: 1.9/28 Rear: 1.9/20
Full load: Front: 2.1/31 Rear: 2.4/34
Emergency: 4.2/60
The bonnet plate gave me some weight info but I don't know if it's what you're after. I've got:
Gross vehicle weight: 1350 kg
Gross comb. weight: 2550 kg
Axle front: 0775
Axle rear: 0630
The plate listed the type as 155DX2 (I think that means it's a cabriolet something).
Some of those figures are listed on my carte grise, as follows:
(F.2) 1350
(F.3) 2550
The back of the carte grise gives me these definitions for the numbers:
(F.2): Masse en charge maximale admissible du v?hicle en service dans l'?tat membre d'immatriculation (en kg)
(F.3): Masse en charge maximale admissible de l'ensemble en service dans l'?tat membre d'immatriculation (en kg)
I can't see anything else that mentions axles in French, but if there's something I've missed, just let me know. My carte grise is beside me.
THE F2 AND F3 FIGURES ARE THE ONES I HAVE MISSING
THANKS AGAIN
on your carte grise what is the engine power output
type 2H engine in kW
and is your insurance group 9cv
thanks again
david
I think we are possibly the only two people on this entire forum with a matching French cars.
looks like i now have all the info needed
unless the French Authorities know better :roll:
David H.
Do you have a fog light button on the right of your dashboard? And do you have yellow high beams? If you have both these, is there a difference between your high beams and your fog lights? My fog light button seems to do absolutely nothing at all.
fogs
david
