Mk1 - G60 ... Not Starting ???
(In Topic #145451)
the engine is all earthed up, belt and braces
im pretty sure the wiring is all right the only bit I'm not too sure on is mating the g60 loom with the original
it used to be a 1.1 and most info is for gti's so i have done it and 98% sure thats right
anyone have more detail on exactly the wires (pin numbers) to mate to the new loom to double check?
fuel pump has been upgraded and seems to be working fine using relay number 80
the ecu seems to be working, used relay number 30
the idle stabiliser seems to be making a strange noise when ignition is on, it ticks a few times then constantly beeps hmmm??
i am getting a spark at the leads but only one spark when you STOP cranking (nothing more than one spark ever time you crank)
i havent got a voltmeter to check that its receiving 12v when cranking but 99.9% sure it is …
the sound from the isv is pretty norm, mine used todo that..
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
ill make an order up of leads coil and few other bits and see if that solves it
i did clean it out with petrol before refitting like it said on matey mate g60 convo but hey not a problem
i will have my eyes open for this bare metal rebuild!!!
