Hydrogen Injection
Hydrogen Injection
Want to know if anybody has tried to incorporate hydrogen/HHO gas into a mk1 Golf with fuel injection? Also need a few technical details regarding injection system and oxygen sensors, if any ?
2007 MK1 Golf Velocity 14i
MK1 is mechanical injection not electronic which I think you'd need to run HHO.
WHAT DO YOU MEAN BY IT WONT WORK… COULD YOU EXPLAIN PLEASE. i NEED ALL THE HELP I CAN GET  :banghead:
Move to mk1 chat as this is mk1 related but does not fit in the technical sections.  Thanks,
James
if its one of those things that makes hydrogen from water and adds it to the fuel....dont bother they are a con. the energy you use making the hydrogen is all you get back when using the hydrogen. you cant make energy for free....
rustys_mk1 said
if its one of those things that makes hydrogen from water and adds it to the fuel….dont bother they are a con. the energy you use making the hydrogen is all you get back when using the hydrogen. you cant make energy for free….
Actually you end up with less! some energy is turned into heat and noise during the process so isn't converted for you to use.
thermodynamics isn't it?
