How to raise the car really high
(In Topic #95418)
Meaty welds
This is it in action, with the axle, fuel tank and other parts removed
This is the area which needs a couple of repair sections
prity clever tho really
novocaine said
very cool. i'd be tempted to make legs that can be fitted so you don't have to leave it on the engine host. something that maybe goes on though hole then has a pin that stops it from coming out. (i'll draw you a picture if it helps)
Yeah did think about that, but I don't need the crane for anything else so it may as well stay there. The axle stands in the pics aren't touching the car or taking any weight, they're simply there in case something funny happens, otherwise I'd be dead!
Fair play tho mate, good way around it, beats crawling around on the floor, will it lift teh front tho 8O
chudd said
I see your welding has improved !
Different welder - made all the difference!
looks fun haha
mk1 golf gti in porsche ocen blue and polished porsche 7slots
want one!!!!
all ive got is axle stands at full length on the square bracket right at the back of the car (well, as of tomorrow anyway) so that's nearly as high as that :wink:
1983 Golf 1.3 Driver:
Life Member
Are you going to enter the Dragons Den?
I'm quite looking forwards to tomorrow's task of refitting the fuel tank, suspension, exhaust and a bunch of other little parts. It shoule make things nice and controllable being able to independently raise and lower the suspension beam into place and the car body itself. The fuel tank is quite light and not too hard to just chuck on, the exhaust should be okay because I can raise the car really high again and do it comfortably.
this looks like a great idea
i am going to do the same in the winter to refurb the back axle,tank etc
has anyone else tried & tested this method
baz
Thinking about it that way it wouldn't even need welding - it could just be drilled and bolted.
Cheers Paul. 8)
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
