HOW MANY MPG U GUYS GETTING? IS MINE A GUZZLA?
(In Topic #96721)
Cheers Rich
mpg
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
Life Member
Generally on a 65-70mph run I get about 42/43mpg and aroun 39mph aroun town.
I find that the mechanical guage is fairly close to the MFA when you zero the MFA on a run and view the guage in comparison.
Dan
1.8 DX series / K-Jet fuel injecton /113,000 miles - original engine never touched:
Over 342 miles at an average speed of 52 mph / mixture of A & B roads plus motorway / used 39 litres of fuel:
Conversion: 4.54609 litres per gallon: 39 litres = 8.58 gallons.
342/8.58 = 39.86 miles/gallon (14.11 kilometres / litre.)
M
<a href="Pictures by jonnymk1 - Photobucket"><img src="http://i264.photobucket.com/albums/ii188/jonnymk1/illiza8-3.jpg" border="0" alt="Photobucket"></a>
If it was running rich enough to use that much fuel I doubt it would run at all.
You need to do a test using the above forumla, brim tank with your normal fuel, zero trip meter, then you run until almost all fuel used and fill up again, try and use the same pump at the same station, note how many litres you put in to brim again. I would suggest on both fills you stop at the first click of the pump that way by using the same pump when you return it should be as accurate as you are going to get in the real world.
then using your recorded mileage and your litres use you can work out the REAL mpg, not what the MFA is telling you, I would think that normal mixed driving would get anything from 28 to 42 and constant hard driving or track would see low 20s, but as I said never down as far as 10 or so. I have had MFAs which had read that kind of figure and they have ALWAYS been wrong and had a fault with the unit or pipe work.
Hope that helps
Mind you :? mine seemed a bit thirsty too and from ultimate Dubs 8O i put ?60 of fuel in it for a 500 mile round trip, which i suppose with fuel prices at the moment, and i wasnt exactly going slow some of the time :wink: was not too bad,
but it was only ?20 less fuel than last year and i went in the VR6 :roll:
