Help! My car cut out yesterday and now wont start again.
(In Topic #141369)
If anyone here has had similair problems, or have any ideas of most likely causes please enlighten me!
In the past two months the things I've replaced are - Battery, plugs, points, condenser and rotor arm.
She had been starting first/second time every time, even on the coldest of mornings but was ticking over at 2000rpm until warmed up then would drop to around 900. The only other promblem I've noticed which happened maybe four days ago was while on the motorway if I really burried my foot down, once close to top speed the car would surge/ slow down a little then pick back up again (perhaps as if not enough fuel was getting through?) Not sure if it could be related but thought worth mentioning. I hope someone
Many thanks Tom.
It's running on the original pierburg carb.
Pierburg checks
and check everything with the carb is ok, can be tricky little **** to get running right!
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
I have located the fuel filter in engine bay but how can I tell wether its blocked? It is around three quarters full at the moment, but unable to see if the fuels clean or not.
There is a sticky thread in the electrical bit of the forum that has a relay layout on it, Im not sure about the 1600 but on the gti its a big relay. It wouldn't take much to pull them one by one and check the pins on all of them anyway just to be sure.
