fabricating a small rear light panel of sorts??
(In Topic #107439)
1, remove my large rear light clusters
2, have a thin piece of metal cut slightly longer than the existing piece
(where the number plate goes) and obviously shaped correctly at each end to accomadate small lights
3, fix it over the top of the existing piece with some adhesive or some sort or self tapping screws (hidden obviously) or better still welded
4, the only bodywork to do as such would be the bottom edge of this panel to fill in and smooth and maybe some of the top, although most of it gets covered by the number plate lights,
5, repaint this section???
6, stand back admire and reach for the kleenex
i hope this make sense?
in effect all you are doing is adding a skin on top of the existing between the inner edges of both rear lights…
PS I KNOW SOME MAY SAY WHY NOT JUST BUY AND WELD ON A SMALL REAR PANEL, BUT THIS WAY SEEMS CHEAPER AND LESS PAINT INTENSIVE, AND I WOULD BE TACKLING IT MYSELF
NOW LET THE SLATING BEGIN!!
Life Member
As for how you're going to do it you really ought to weld it, don't see screwing it as an option, that would just be terrible. Ultimately to be honest people have done much worse and always will, personal choice is to be applauded! However it all depends on how professional the finish is, if you botch it then you're in a world of hurt. Personally I'd be very weary.
Your call!
T
and im not exactly interested in butchering it as you so politely put it hence why im asking if its possible before i attempt it
cheers mate,
tbh im not one for modding cars atall, if i had the money i would do the job properly or better still buy a series 1, i just had this crazy idea while driving home and thought i would throw it out there for debate,
im sure the way i worded it by mentioning screws and the such like didnt sound great, but if i were to attempt the job it would be in the correct manor
thanks again
chudd said
Did you no in the early 80's that a swop to 'Larger lights' from small was a popular update to make your MK1 more modern :mrgreen:
Now its the other way round .
Good luck with it .
Funny old world.
T
if i remember rightly its rear panel is formed from sheet steel and cut down series 2 lights 2…
Life Member
littlelegs said
surely the only line that would change is the one at the bottom of the said panel where it angles itself back out, but the only difference is the depth of the material that will go on isnt it once its smoothed back in??
Why don't you take a tape measure to both panels if you want it to look original? As the above pic shows, the swage line is incorrect. The bottom of the lights is supposed to be ABOVE the swage line, not parallel to it.
hey dan, nice work with the photos mate i see the problem clearly now,
i had assumed the lights were the same height on both series 1+2,
i suppose the the only quick fix way would be like the one in lawsy's pic, which looks ok, but like dubboy says is clearly not original looking,
thanks for all info though everyone
im off into town now to sell my arse for new metal
