Engine sizes
(In Topic #127197)
Engine sizes
peteh said
thanks. what BHP are the 1.6 GL's
I'm not convinced you can get a 1.6GL, at least in hatchback form. At launch, it was a 1.5 and they were badged N, L, LS, S, GL, GLS. The GL was not available in UK and was high spec trim but 1.3 engine; the GLS was high spec trim and 1.5 engine. In 1975 they changed the 1.5 to 1.6, and in 1977 they changed back to a 1.5. When the badges were changed, they went approx:
L –> C
LS –> CL
GLS –> GL
for the UK. So the GL with a big block always had a 1.5, not 1.6.
Cabriolets (non-injection, bottom range ones) started out as 1.5 and were badged GLS. They changed to GL badging, then 1.6 engine (not sure if same time though). And this continued until around 1986 when the Clipper took over from the GL as the bottom of the range. The 1.6 in a cabriolet (well, 1984 on for sure) was a different unit than the 1588cc of the earlier hatchbacks, it was a 1595cc unit also used in Jetta and Golf Mk2.
Unless my 1.5 has a 1.6 cylinder head on top lol.
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
