cracked bulk head.
(In Topic #93769)
cracked bulk head.
so its going back to tim for some serious work.
looks like i will be golf less for a few months.
never rains but it pours huh?
anyone know exactly what could of caused this? everyone ive spoken to so far has just said "thats a bit odd" and if there is anything i can do (driving style or otherwise) to prevent it happening again id love to know.
thats why i brought her.
but ill keep that in mind cheers.
happened to me on my first golf with crappy alloys on it, stick with smaller oldskool alloys :wink:
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
i honestly thought id done everything right
dubstar74 said
Bigger heavier cheap aftermarket alloy wheels usually cause this problem
Wot, are you sure?
Tian 8O
There's 2 places I can think the bulkhead would normally fail or corrode, and both are quite repairable. The first, is around the clutch cable hole. You can buy a repair panel for this area; or repair it with a much simpler/cruder plate if needs be. The other place is the brackets holding the steering rack to the bulkhead. This is normally easy enough to repair by welding.
its going to head back to tim to do, seeing as it looks like he will be making a fortune out of me with the other restro work i need to do… may as well get it all done in the same place.
www.autohausdolby.co.uk
VW Specialist, Sheffield
im not sure if it was the idiot in the Mercedes who decided to hurt my car, or if it was the idiots who tried to steal it.
merry christmas? BAH HUMBUG I SAY
edit: or when they dropped its rear wheels on the jaguar in the garage.
anyone know a good rabbi? i think i need my car exorcised….
u can't worry about money if you own an old car i think its just part and parcel with any motor, as my dad says
cars are just skips with wheels to throw your money into whilst you drive
Josh
Josh
…especially cabbys
..I said it before Wooders says it
also: my friends G-Wagon also has a cracked bulk head, but he hit a deer yesterday and the truck is a write off.
i had the same bulkhead problem. i was told the main reason why this happens is if your clutch is on its way out, causing more tension on the bulkhead. ive had my rivage for about 1 1/2 year.
1st the clutch cable coming through the bulkhead was ripping itself to shreads scraping against metal. i could see the was a panel soo there were problems before i bought it.
i took it to a garage who put a newer better panel covering the bulkhead. it was ok for while until the cable was shreading itself again, i took the car to my mecahnic who works at home, he put a few washers by the bulkhead and put a thick plastic tube where the cable goes through the bulkhead to the clutch so no scraping with the cable n metal, and lubricating the tube inside.
hope this helps
i was going to get it welded for ?100
but my mechanic charged me ?20 and its fine, he says its safe and has been for many months, jus have to change the clutch to get rid of the tension
